Завръщането на БМВ М1 ? Не БМВ 1 серия М купе
Регистриран на: 24.02.2008
Местоположение: Варна/Разград
Кара: Е34 Individual
Мнение от ИлХиТо » 09 Дек 2009, 15:14
Return of the BMW M1
The BMW M1 name returns, but will it appear on a hot 1-series or a new supercar?
BMW has confirmed it is to build an M1 – although the badge could be worn by one of two models currently under development. First up is a baby M-car, but many within BMW would love the name to appear on the rump of an Mercedes SLS AMG-rivalling supercar instead.
M Division’s priority is a sub-M3 model based on the 1-series and using a heavily-tweaked version of the 135i’s twin-turbo straight-six producing around 400bhp and 370lb ft of torque. This will be mated to the new seven-speed double-clutch gearbox and is likely to drive the rear wheels through the M3’s trick differential.
Well-placed BMW sources predict that other M-car features are likely, including the M3’s complete suspension, while to further boost its cred the engineers are working to remove 70kg from the 135i’s pudgy 1485kg kerb weight.
Visually, expect the little M to be closely based on the Tii concept car BMW displayed at the 2007 Tokyo motor show, with enlarged front air intakes and a less subtle bootlid lip.
Expect the new model to go on sale as soon as early 2011. As for the price, our source added: ‘If you look at M3 and 135i, there’s a lot of space for pricing. We’re thinking about half way between them.’
The trickiest decision could be on the name, though. We understand that BMW’s ‘old guard’ have problems with a 1-series wearing the M1 badge because of the original they developed in the 1970s. They would prefer the name to be held back until the arrival of a latter-day replacement for the 1978 mid-engined supercar, and that’s a project that M Division is now actively working on. See the M1 Homage concept here.
In a sharp departure from the past, it is believed that this new supercar, due in late 2012, will use both electric and high-revving petrol motors to achieve sub-4sec 0-60mph performance. The drivetrain is said to take lessons from the Vision EfficientDynamics hybrid (above) revealed at this year’s Frankfurt motor show, mating BMW’s twin-turbo 4.4-litre V8 with twin electric motors. The new car would use this system to provide added boost at low rpm before swinging across to petrol power at higher revs, much like the X6 ActiveHybrid does.
‘M Division should have its own supercar built in three years,’ a senior BMW source said, ‘but we need to sell some cars first. That’s why the 1-series M-car is the higher priority.’
Завръщането на БМВ М1.
БМВ М1 се завръща, но дали това име ще се носи от гореща версия на 1-а серия или ще бъде изцяло нов суперспортен автомобил?
БМВ потвърдиха, че ще произвеждат М1 – въпреки, че в момента може да се носи от един от двата модела които се разработват в момента. Първият от тях е т.нар. „малък” М автомобил, но много от феновете на БМВ очакват това да е суперспортен модел от ранга на токущо появилия се Мерцедес-Бенц СЛС АМГ.
Приоритет на М отдела на баварския концерн е модел позициониран под иконата М3 – базиран на 135i, но с подобрени характеристики на двигателя и мощност от порядъка на 400 к.с., който ще бъде окомплектован с новата седем степенна скоростна кутия с два съединителя, и естетвено задно предаване и самоблокиращ се диференциал.
Добре осведомен източник от БМВ твърди, че другият модел на М отдела ще използва преработено окачване от настоящият модел М3, а в момента целта на инженерите е да редуцират около 70 кг от настоящото тегло на 135i.
Визуално „малкият” М модел се очаква да бъде много близък до представеният на Токио мотор шоу 2007 135tii концепт, като промените главно ще бъдат малко по-големи отвори за входящия въздух отпред и дискретен спойлер на багажника. Очакава се новият модел да се появи в началото на 2011 година. Относно цената нашият източник каза : „ Като сравните цените на настоящото М3 и 135i, ще видите че има ценова ниша за модел между тях „ .
Трудностите ще са свързани най-вече с името на този модел, тъй както знаем ///М1 се е носил от славния модел от близкото минало(1970 г) със центарално разположен двигател. Желанието на БМВ е това име да се задържи докато се появи реалният наследник на легедарният модел ///М1, като по тази задача в отдела се работи доста усилено и доказателство за това е концепта М1Homepage.
Следвайки славната история на ///М1, се очаква неговият наследник, който се очаква през 2012 г. да използва два електромотора в кобинация с високооборотен бензинов двигател с цел постигане на ускорение до 60 мили/час (около 90 км/ч) под 4 секунди.За задвижването ще се използват постиженията показани чрез концепта Vision EfficientDynamics hybrid, представен на тазгодишното изложения във Франкфурт, като се очаква това да е 4.4 л би-турбо V8 куплиран с два електромотора. По този начин бъдещият супер модел ще има голям въртящ момент при ниски обороти, докато при високите оборотни режими това ще се изпълнява от би-турбо мотора V8, по подобие на системата в наскоро представения БМВ Х6 Актив хибрид.
„М поделението на концерна ще има свой суперавтомобил в рамките на 3 години” казва нашият източник „ но преди това трябва осигурим продажбите на някои модели, и поради тази причина разработването на /// М автомобил на базата на 1-а серия е много важно за нас.”
Източник: http://www.evo.co.uk/news/evonews/24598 ... mw_m1.html
http://www.1addicts.com/forums/showthread.php?t=318616
П.С. Очакват ни доста интересни новости от БМВ :bowdown: :bowdown: :bowdown:
Последна промяна ИлХиТо на 09 Юли 2010, 8:32, променена общо 1 път
Регистриран на: 12.07.2009
Кара: Е60 530д
Re: Завръщането на БМВ М1 !!!?
Мнение от chepila » 09 Дек 2009, 21:44
М модел на базата на 1-ва серия ще има в близките 1-2 години,то е ясно.
Ама за легендария М1 маи ще трябва да почакаме доста,поне така мисля аз.
Регистриран на: 16.06.2008
Мнение от Лалов » 10 Дек 2009, 0:42
С нетърпение чакам М-модел на базата на 1-а Серия и изцяло М-модел разработен от M GmbH :lalala:
@BMW Malchugan, браво за првеода :wave:
Любимец на Кралицата
Регистриран на: 6.04.2008
Мечтае да кара: M3 CSL
Мнение от ///M_Martin » 10 Дек 2009, 20:47
Много е хубава но според мен това ще е ///М на 1-ва серия и беше крайно време да стане
Регистриран на: 22.09.2008
Местоположение: Видин
Кара: E21 320;E46 320d
Мечтае да кара: E36 M3 GT
Мнение от nik420 » 10 Дек 2009, 21:11
Дано стане така :yes:
Мнение от Лалов » 10 Дек 2009, 22:21
Говори се, че по време на автосалона в Дубай (10th Dubai International Motor Show) BMW ще покаже новото М1 :kuku: :D
А той е следващата седмица :lol:
Регистриран на: 21.11.2004
Местоположение: Sofiq
Мнение от BAYRON » 10 Дек 2009, 22:38
1M :wave:
BMW Performance
Регистриран на: 9.05.2008
Местоположение: М Кар
Мнение от MCar » 11 Дек 2009, 0:10
Хорейшио написа:Говори се, че по време на автосалона в Дубай (10th Dubai International Motor Show) BMW ще покаже новото М1 :kuku: :D
По-скоро ще представят BMW Vision EfficientDynamics Concept, на който се предполага, че ще е базиран М1. Иначе не виждам как ще е готов М1 дотогава.
А М версията на базата на 135i, явно няма да я видим веднага.
Мнение от ИлХиТо » 16 Яну 2010, 10:29
Снимки на ///М версията на серия 1 може би??? 8).
Според статия в английското списание това е тестово муле на следващата генерация на първа серия. Аз не мисля така, обаче. На третата снимка добре се вижда дифузьора, а при увеличение на снимката се вижда и "двуцевката" :mhihi: . Коментарите на колегите от http://www.1addicts.com/forums/showthread.php?t=341213 са в същата посока. Ще трябва да почакаме за да видим какво са подготвили от БМВ ;) .
Мнение от ИлХиТо » 19 Яну 2010, 18:58
Ето и едно видео на мистериозната единичка ;)
http://www.bimmertoday.de/2010/01/19/er ... er-m-gmbh/
Регистриран на: 3.12.2009
Местоположение: Тополовград
Кара: e60 530d 04'/e60 530i 06'/e36 318i
Мечтае да кара: цял живот BMW
Детайли за колата: Е60 М57D30N
E60 N52B30
Е46 M43B19TU
E36 M43B18
Мнение от Plamen_Shopov_BMW » 25 Яну 2010, 1:15
дано наистина след 2 годинки да видим М1 по улиците, а за М версията на 1 серия се говори от доста време и просто е ясно, че ще има съвсем скоро, но най-вероятно ще е както Х6 М, примерно ще се казва 135 М ... не ми се вярва от БМВ да използват наименованието М1, при положение, че това е името на легендарния автомобил от края на 70-те
BMW Performance
Мнение от MCar » 25 Яну 2010, 1:30
Plamen_Shopov_BMW написа:дано наистина след 2 годинки да видим М1 по улиците, а за М версията на 1 серия се говори от доста време и просто е ясно, че ще има съвсем скоро, но най-вероятно ще е както Х6 М, примерно ще се казва 135 М ... не ми се вярва от БМВ да използват наименованието М1, при положение, че това е името на легендарния автомобил от края на 70-те
Има вариант да се казва 1-ва серия Supersport или 1-ва серия Tii (от концепта, който показаха преди известно време). Ще видим...
Мнение от Лалов » 25 Яну 2010, 1:49
Мда, и тези наименования съ възможни :) 1-Series M Coupe. Не звучи лошо.
Първи тийзър снимки: http://www.1addicts.com/forums/showthread.php?t=341213
master of the force
Регистриран на: 11.08.2003
Местоположение: planet torque
Мнение от alx » 31 Яну 2010, 18:12
м на 1ва серия мисля че ще се казва 1м.
но това 1ва серия- не го разбирам. ако беше едно 500 кила по-леко...щеше точно да е където се опитват да го сложат.. ама да ми тежи колкото 3-та серия и да е по-дребно... не го разбирам...
алекс
трабант 601с
разни други возила
Регистриран на: 9.02.2007
Мнение от acho.rs » 31 Яну 2010, 18:34
alx написа:м на 1ва серия мисля че ще се казва 1м.
Може този вариант да е олекотен :roll: Особено сега като пуснаха Е92 335ис , тази еденичка ако не е олекотена , трудно ще намери клиенти ...
Назад към Основен Форум
