mp3 в колата (Grom) (Upgraded with Bluetooth)
Или всичките неща, които можем да натъпчем в един автомобил.
Модератор: Icco
Регистриран на: 8.05.2009
Кара: 530д
Re: mp3 в колата (Grom)
Мнение от nikolae » 03 Окт 2010, 19:17
Имам отговор от Alberto :-)
Hello,
Thank you for your email.
Please try an updated firmware attached. It is designed to resolve he issue.
To apply the firmware, please do the following:
* Copy or cut file attached named gromusb2.hex
* Paste or place the file on a USB flash drive (stick) into the root of the drive.
* Turn on the ignition & radio and attach the USB stick to the GROM USB unit.
* The light on a stick should blink for several seconds (wait 5 seconds).
* Please turn vehicle completely OFF for 5 seconds and then restart.
* New update should be loaded.
* Make sure you remove gromusb2.hex from the stick to avoid unwanted firmware change later.
Switch to CDC (GROM mode)
1. Press FM (or AM), wait for 1 second.
2. Press CD/MODE/DISC (whichever applies). You should hear an announcement of the currently active mode. If you do not hear the announcement repeat steps 1 & 2. If announcement heard is not the desired mode, immediately go to step 3.
3. Press > (next track button).
4. Voice will announce the mode. If mode is not desired, immediately repeat step 3.
5. Wait for 2 seconds for selected mode to become active.
All FAT16/32 formatted storages:
- USB sticks/hard drives
- SD/CF/MMC cards with card reader USB interface
The GROM USB supports only FAT16/32 formatted storages. NTFS is not supported!
# MP3 layer 1,2,3 bitrate up to 320Kbps
# WMA (no DRM) bitrate up to 384Kbps
# AAC/MP4/iTunes+ (no DRM). Bitrate up to 384Kbps
# OGG/Vorbis bitrate up to 384Kbps
Please test and let us know your results.
После ще пробвам, утре ще пиша
Ако някой иска файла, ще му го пратя.
Регистриран на: 1.02.2010
Кара: F34 320d
Мечтае да кара: G32
Детайли за колата: 320d GT B47
Мнение от mistyrain » 04 Окт 2010, 10:19
Супер колега. Сложи го и кажи дали ти е оправило проблема. В този нов фирм има ли други фиксове като например повтарящите се песни или не е ставало въпрос. Ще съм много благодарен ако ми го пратиш.
Последна промяна mistyrain на 04 Окт 2010, 14:09, променена общо 1 път
Кара: 530д
Мнение от nikolae » 04 Окт 2010, 10:57
Пуснах ти го на мейла, изтрий го от поста си да не го хване някой робот.
Не знам обаче дали да го слагаш, ако нямаш никакви проблеми.
Аз бях му пратил снимка на касетофона, който имам и не знам какво точно са правили,
но пък ако искаш го пробвай и пиши дали има разлика.
Аз ги карам да сложат опция за crossfade м/у песните
ще бъде готино :-)
Кара: F34 320d
Мечтае да кара: G32
Мнение от mistyrain » 04 Окт 2010, 14:11
Мерси много колега. Ще видя какво да направя, че хората са казали да не се поправя онова дето не е счупено, ама ние все си ръчкаме :)
Кара: 530д
Мнение от nikolae » 07 Окт 2010, 11:55
А защо да нямаме скрол на текста ?
Nikolay,
Original i-bus used in BMW does not allow high traffic data to be sent. In case of text the amount of data is very large and may influence other components,
So we're trying to minimize the impact by updating text every 5 seconds and not 0.3 seconds suitable for scrolling.
We plan on having such option available shortly but it is not advised to use it.
Please check our downloads page for more updates,
Dmitry/
Има и по-нова версия:
http://www.gromaudio.com/software.html
Кара: 530д
Мнение от nikolae » 08 Окт 2010, 14:22
От громЪТ :-)
Hi Nikolay,
Please use V36 it should fix AC issues.
There were no changes besides stability improvements.
We do ont have text scrolling at the moment. Will be in 2-3 weeks, <-----
Dmitry/
Супер а !
Регистриран на: 14.01.2009
Мнение от batence » 11 Окт 2010, 13:57
Здравейте!
Що се отнася за изходи за усилвател от ГРОМА,може да се извадят изходи обаче е безмислено, защото няма как да се контролира усилването и аудио настройките.Най- добрия вариант е изкарване изходи от самия плеър,правил съм го няколко пъти и става перфектно!
Мнение от batence » 11 Окт 2010, 13:59
nikolae написа:здравейте,
Аз съм с радиото с касетката и сложих гром-а.
Почти всичко работи ок, който каквото е писал като плюсове в повечето случаи е прав.
Работи всичко където е описани - много папки, имена на файловете /първо чете ID3v1 tag, после ID3v2 tag и накрая името на файла, в случай, че някой се интересува и малко ще трябва да си коригирвате мп3-тата за да изглеждат читаво на дисплея/
бъговете, които аз съм забелязал до тук (ползвам последния фирмуер 32 нещо такова).
- Много, ама много често шашка климатика, и не само при мене е така.
Случва се особено, когато има нов фолдър или тракове, при нов фолдър ако цъкате песните вътре, постоянно ще го спира/пуска
говоря се само за климатика /копчето със снежинката/ ами и цялото парно - дисплея.
От гром отговориха, че работят в/у фирмъуера.
- Другото, което забелязах, когато слушате тракове и искате от волана да смените парче, при първо натискане на волана Не сменя песен, чак при второ, но вече като влезе в "режим" ги сменя нормално от първо натискане.
- При мене, при другите не знам, рандом/random режима не се пуска всеки път при задържане на SC бутона
по-скоро не е бъг а.. не знам как да го кажа.
Имате папки - 1 2 3 4 5 6
може във всяка папка да имате много тракове (до 999 мисля)
но ако в папка 1 имате тракове + папки, малко трудно се ровят
песните в потпапките ги реди, после ако други подпапки и накрая траковете
Като цяло доста готина играчка, много екстри и удобства, но честно казано
си мисля, че CD-тата вадеха по-добър звук - и нормално
не съм пробвал какво точно чете освен мп3 - mp4,wav,aac и т.н.
с новата 36 версия се решават споменатите проблеми
Регистриран на: 8.10.2010
Местоположение: София/Кюстендил
Кара: Продаде колата
Мечтае да кара: Бързо, голямо и черно BMW
Мнение от sshtskv » 14 Ное 2010, 16:15
Имам въпрос към тези, които имат #Grom Audio, монтиран на #е46. Интересува ме ориентировъчното време за извършване на интерполацията и качеството на самото обслужване. Внимателно ли се демонтира и монтират елементите и прочее. Както и, върши ли работа устройството?
Кара: 530д
Мнение от nikolae » 14 Ное 2010, 18:18
BMW/MINI/Rover Bluetooth ready firmware
http://gromaudio.com/downloads/firmware ... bmw_38.hex
някой иска ли да го пробва, че колата не е в мене за известно време
Кара: F34 320d
Мечтае да кара: G32
Мнение от mistyrain » 16 Ное 2010, 12:16
Sasho Tsukev написа:Имам въпрос към тези, които имат #Grom Audio, монтиран на #е46. Интересува ме ориентировъчното време за извършване на интерполацията и качеството на самото обслужване. Внимателно ли се демонтира и монтират елементите и прочее. Както и, върши ли работа устройството?
Здравей колега,
Аз съм доволен от начина на монтиране. Момчето очевидно беше правил това много пъти, не бързаше да претупа, направи тестове, завърза кабелите културно.
nikolae - ехх, де да имах и аз bluetooth модул :)
Кара: 530д
Мнение от nikolae » 16 Ное 2010, 13:56
Все си мислих, че някой го е пробвал.
Аз ще рискувам 35 долара
Мнение от sshtskv » 16 Ное 2010, 16:47
mistyrain написа:
Здравей колега,
Днес ми монтира и на мен с последния firmware. Наистина съм много доволен от момчето и от устройството! Монтажа протече много внимателно. Проведоха се доста тестове, докато той не се убеди, че всичко е в ред. Когато е създадено това устройство, наистина е мислено. Има всичко, от което аз имам нужда.
Мнение от sshtskv » 26 Дек 2010, 18:31
Чувате ли шум с увеличаване на звука или си въобразявам?
Кара: F34 320d
Мечтае да кара: G32
Мнение от mistyrain » 29 Дек 2010, 1:39
Аз от както съм го купил, това е и когато съм направил темата, не съм сменял Firmware поради простата теория да не поправям нещо което не е счупено :) . Като увеличавам няма дошълнителен шум, имам предвид че по време на увеличаването няма нищо допълнително, но иначе ако песента има тих или нулев момент си има статичен/паразитен шум.
Назад към Car аудио и видео
