нисан гтр става по-силен...
master of the force
Online
Регистриран на: 11.08.2003
Местоположение: planet torque
Мнение от alx » 19 Окт 2010, 20:26
Nissan Releases the 11MY Nissan GT-R
YOKOHAMA (October 18, 2010) - Nissan Motor Co., Ltd. today announced the launch of the 11MY Nissan GT-R, which goes on sale November 17th at Nissan dealers nationwide in Japan.
For 11MY, GT-R features improved engine output and torque, greater fuel efficiency, revised handling, a refreshed exterior with improved aerodynamics, revised interior treatment and new wheels and tires. The large number of enhancements for the new model year is part of the continuous advancement of the GT-R design, technology and performance since its debut in December 2007. Nissan has also enhanced the level of after-sales support for GT-R owners, providing even greater value for customers.
The "World of GT-R" expands again this year with the addition of a racing circuit use-only "Club Track" edition and an ultra-exclusive "EGOIST" version that can be custom-ordered according to the precise desires of each individual customer. The complete 11MY Nissan GT-R model lineup now includes six versions - the "Pure edition," "Black edition," "Premium edition," "SpecV," "Club Track" and "EGOIST" - allowing customers to choose the exact level of dynamic performance and style to meet their various needs.
The 11MY Nissan GT-R will also be released in North America, Europe and other regions after February 2011. Nissan is considering introducing EGOIST in Europe and the Middle East, and the Club Track edition in Europe as well.
11MY Nissan GT-R Overview
Developed under the theme of offering the "world's best multi-performance and responsive driving pleasure," every area of the GT-R has been carefully rethought or retuned for 11MY. The changes range from greater body stability and strength and improved aerodynamics performance to a sportier interior and enhanced performance. Following are the key enhancements of the creative GT-R design.
1. Mechanism
Engine and Transmission Enhancements
* By modifying the boost pressure of the turbocharger, valve timing and air mixture ratio, reducing intake air resistance by enlarging the inlet pipe diameter, and reducing exhaust air resistance through use of an enlarged section of exhaust pipe, fuel economy is improved to 8.5km/L (10-15 mode) or 8.6km/L (JC08 mode).
* At the same time, the engine output is significantly improved to 390kW(530ps)/6,400rpm with maximum torque of 612N・m(62.5kgf・m) from 3,200 to 6,000 rpm. A new red color engine cover is used to demonstrate its greater performance.
* Cleaner emissions are realized through adopting an ultra-low precious metal catalyst and ECM with high-capacity microprocessor - achieving SU-LEV certification levels (emitting 75% fewer emissions than Japan's 2005 exhaust emission standards).
* A new SAVE mode is adopted, which optimizes driving torque and modifies the shift schedule to improve actual fuel economy when driving highways or open roads. This mode also helps reduce ankle fatigue.
* Starting performance while selecting "R mode" for the transmission and VDC-R is improved.
* To control tight corner braking phenomenon, which can occur when starting the vehicle while turning the steering wheel, 2WD mode is added to temporarily shift to 2WD driving.
* When the vehicle speed is below 10km/h and the steering wheel is turned more than halfway.
Body Strengthening
* A highly rigid, lightweight strut supporting bar, made of carbon composite with aluminum honeycomb material, is installed in the partition wall of the engine compartment. By linking the right and left struts to quickly receive suspension input, the vehicle body's responsiveness to driving operation is enhanced.
* An additional support member is installed in the passenger side of the instrument panel. Responsiveness of the vehicle body is further improved by enhanced rigidity for connection with the engine compartment.
* For further production accuracy, the fitting precision of the body panels is enhanced and a higher-precision G sensor is utilized in checking the instrument panel during the vibration testing of each vehicle body.
Suspension and Braking Modifications
* For the front suspension, the lever ratio of the springs, shock absorbers and stabilizer bar is modified to improve the vertical load response of the tires. Front caster angle is increased from 5°35 to 6°00 to improve tire road holding ability when turning and stability while driving straight.
* For the rear suspension, toe performance is modified by changing the roll center height to a lower position in order to improve tire grip while making turns and to better communicate driving feel.
* An aluminum free-piston shock absorber design is newly developed which generates more precise damping force to constantly provide stable road holding and a load shift that quickly responds to driver's intention. Reduced friction in the shock absorbers provides high quality, smooth ride comfort.
* A thin, large-diameter rotor (Φ390) developed uniquely by Nissan is adopted to improve braking force, fade resistance, pedal control ability and extend brake rotor life for sporty driving.
Wheels and Tires
* The 11MY GT-R also features newly designed, lighter weight and more rigid forged aluminum-alloy wheels. Made by Rays, the wheels help improve tire responsiveness to vertical load. Knurling inside the wheel is modified to avoid deviation of tire rotation direction caused by the higher engine output. On the wheel surface, a new Hyper Blue Black Chrome color is adopted, which expresses high quality and high-performance feel. The wheels' deep gloss is created by utilization of a five-layer coating process.
* The Dunlop SP SPORT MAXX GT 600 DSST CTT tires have a new compound to improve tire grip. With renewed structure and improved tread and sidewall rigidity, straight-line stability in rutted roads is enhanced.
2. Design
Exterior and aerodynamics
* Even with GT-R's already intense and stable form, its world-leading aerodynamics performance is further improved through a number of significant enhancements. Downforce is increased by about 10%, while the coefficient of drag is further reduced from 0.27 to 0.26.
* Stability is improved by enlarged bumper and grille openings
* The front bumper is newly designed with double rectifier fins and Hyper Daylight with a large-diameter reflecting surface and high intensity white-color LED lights. The design increases front downforce by about 10%, while also reducing air resistance inside the engine compartment. The volume of air that passes through the radiator and cools down the front brakes is also increased.
* Additional plated parts are used for headlight inner panels, enhancing the car's strong presence.
* The redesigned rear bumper features a lower center of gravity than the previous design, created by a sculptured lower portion and extended length. Underfloor cooling performance is enhanced with air resistance reduced by extending a rear diffuser.
* Cooling performance for the muffler is improved and rear downforce is increased by about 10% through use of a new rear bumper air outlet, which helps remove air in the rear wheelhouses.
* A newly designed tailpipe finisher with enlarged diameter is adopted. Rear high-intensity LED fog lamps are provided as standard equipment to help improve visibility from vehicles behind in rainy or snowy conditions.
* Six exterior colors are available, including two new colors: Meteo Flake Black Pearl (2P) and Aurora Flare Blue Pearl (2P). (Both are special colors.)
Interior
* A newly shaped instrument panel pad and navigation system display finisher are adopted, with stitch lines changed to express an enhanced quality feel.
* Real carbon center cluster finisher is used, along with matte black finished switches.
* The GT-R emblem at the center of the steering wheel has a new velour-like coating, expressing a glossy texture. For the paddle shift, a coating exposing the magnesium base material is applied.
* Chrome-plated rings in the console and air-conditioner outlets are finished with a new black smoky coating, expressing greater sportiness.
Seat
* Seats for Pure edition and Premium edition provide an improved level of comfort and safety while cornering. In addition, fatigue levels are reduced for the thighs and lower back by changing the shape, extending the length of seating surface and refurbishing the cushion stroke. A new seatback design seatback is adopted to improve fit.
* The Black edition has leather-appointed bucket seats using a Recaro design based on the structure of Pure edition and Premium edition seats.
SpecV
Modifications applicable only to the SpecV are as follows:
* Engine modifications are the same as the base model with improved maximum power output and torque, as well as enhanced fuel economy, except maximum torque is improved to 612N・m(62.5kgf・m)/ 3,200~6,000rpm (632N・m(64.5kgf・m)/ 3,600~5,600rpm). (Figures in parenthesis are when high geared boost is used.)
* To improve abrasion resistance and stability in racing circuit driving, rear brake pad material is changed and VDC (Vehicle Dynamic Control) balance under braking is modified.
* Dunlop SP SPORT MAXX GT 600 DSST CTT tire is adopted as a standard feature.
* Special Rays lightweight aluminum forging wheels for the SpecV are adopted from the previous model with the color changed to Metallic Black.
също така изглежда, че е доста бърз и на ринг-а:
http://jalopnik.com/5666310/2012-nissan ... -ring-time
алекс
трабант 601с
разни други возила
Регистриран на: 9.02.2007
Местоположение: Sofiq
Re: нисан гтр става по-силен...
Мнение от acho.rs » 19 Окт 2010, 20:39
In bulgarian , pleeeeease ...
Регистриран на: 29.06.2006
Мнение от MatriX_Fucked » 19 Окт 2010, 21:39
Май от нисан са гледали клипа във вбокс-а, как ланчата бие гтр-а, кат маче у дирек! :D
http://vbox7.com/play:6181b145
:lol:
Без страх, без спирачка!
Регистриран на: 5.09.2006
Кара: м си.
Мнение от Joro17 » 19 Окт 2010, 22:51
acho.rs написа:In bulgarian , pleeeeease ...
Малко по-постно
http://www.automedia.bg/news/article_10936.html
Регистриран на: 7.04.2004
Местоположение: CA
Кара: конете да бягат
Мнение от steeN » 20 Окт 2010, 8:05
явно бая скучаят инженерите на нисан... има ли нещо дето да не са барнали? нищо не са си оставили за следващия модел ;)
Регистриран на: 17.04.2008
Местоположение: Кукерландия
Мнение от saleen » 20 Окт 2010, 9:17
Този Нисан има уникално силен старт, обаче след това в по- високите скорости според мен издиша.
Регистриран на: 3.09.2003
Кара: M340i
Мечтае да кара: Калибра
Мнение от vicho » 20 Окт 2010, 15:01
saleen написа:Този Нисан има уникално силен старт, обаче след това в по- високите скорости според мен издиша.
чу ли се каква глупост написа ...
Tази кола вдига над 315 км/ч в сток състояние, ти на това издишане ли му викаш, да не говорим за тунинга, че там става грозно!
GT-R е една от най-силните коли, които съществуват на пазара и няма аналог в неговия ценови клас, че и в доста по-горните.
Регистриран на: 30.03.2009
Местоположение: U gorata
Кара: prascho, nervaka i redneckmobil
Мечтае да кара: "samodelna" kola
Мнение от BMW_RIDER » 20 Окт 2010, 15:14
vicho написа:
Еми то и ти не си от най-правите. Има аналог в неговия ценови клас - със ДОБРЕ каран корвет з06 са на кантар а той е 10К$ по евтин от нисана. А добре карани Зр1 и вайпър ацр които са 10 к$ по скъпи го бият.
Колегата имаше в предвид според мен ,че след 150км/ч това ,че нисана е над 1700кг и има доста загуби на мощност заради 4х4 и трансмисията с два съединителя, не е толкова еластичен и бърз колкото по леки коли с по големи мотори. Всичките коли които написах по горе бият нисана на rolling драг. И наистина времената 0 -100 на нисана без ЛК са над 4 сек.
НО, няма спор ,че това е една от най-способните и най-добрите в момента коли. И айде да не е без аналог, но аналозите му се нуждаят от факир зад волана за да докарат неговите времена.
Кара: M340i
Мнение от vicho » 20 Окт 2010, 15:31
BMW_RIDER написа:Еми то и ти не си от най-правите.
аз не държа да съм от най-правите ;)
BMW_RIDER написа:които са 10 к$ по скъпи го бият
$10к са доста пари, особенно при тези коли или греша нещо
BMW_RIDER написа:И наистина времената 0 -100 на нисана без ЛК са над 4 сек.
то лънч (обяд :mhihi: ) контрола е за окраса :yes:
BMW_RIDER написа:със ДОБРЕ каран корвет з06 са на кантар
не мисля :D
Общо взето, безсмислено е да обясняваш, как GT-R се "задъхва" :yes:
Мнение от acho.rs » 20 Окт 2010, 15:36
Без ЛК е 4,1+ сек до 100те и не съм сигурен дали в Европа не се продаваше без ЛК (поне така твърдят някой медии) . Времето на Нисана до 200 е малко слабичко (около 12,5-13,0 сек) но след това е направо трагично . На писта явно спартанското окачване , АВДто и 20ките правят чудеса , но в реалния живот на нормална магистрална дръпка 150-250 ще падне от всичките си конкуренти .
Сега кое колко може да се донапомпи , ако беше някакъв критерии , щеше да има само Импреси и Евота ... както и 1.8Тръцове по 600 коня :mhihi: И да не забравяме какво става ако един вайпър се турбинира :driving:
Мнение от saleen » 20 Окт 2010, 15:46
vicho написа:
На фона на отличното ускорение за тия 480 коня, което дава от 0-100 км/ч (с лънч контрол някъде се цитира дори и време 3 сек.) в по- високите скорости не е чак толкова бърз http://www.youtube.com/watch?v=odwyeIq7mxs след 3:30 мин. на клипа се вижда (първо дърпа яко напред, но после бързо му стопяват преднината и пада от корвета).
Регистриран на: 13.12.2007
Мнение от SKISA » 20 Окт 2010, 15:51
а що никой не говори за нисана на писта!?!? драгове,лънчове , па ако се турбинира некой зет 06 ,па ако му турат ракетен двигател......! ше турбинират баба си американците!! да изкарат некоя от техните изтребители и да се замерят на ринга с нисана ,па да ги видим! включително и тая ланча ,дето го дръпна на драга....!! и като ще сравняваме -сравняваме само сток!! не некой ,дето е наврел едно буре с барут в гъза си и се бега.....
то карането не е само направо!! за тва са турили тва търкало ,дето го държиме с ръчички......
нисана бил спрел....!!!!! и на мене роман абрамович ми е грозен ,ма некакси на него не му пука!! и на даря не и пука.....
карал съм тоя нисан на правата от оувърдрайв до разклона за равно поле и просто ми падна главата отзад на задната седалка ,като се има впредвид ,че изобщо не посмях да натисна здраво ,щото за пръв път сядам....! никога ,по никакъв повод не съм имал такова усещане в друга кола ,а ....повярвайте ми ,съм се качвал в доста такива.......!! 3,4 мисля ,че му е спринта до 100 ...! на 4 гуми ,без да му е отворена вратата и му е включен лънча.....
Кара: M340i
Мнение от vicho » 20 Окт 2010, 16:50
saleen написа:...
стига гледахте тия клипове с тунинговани автомобили, въпреки, че пък тунингован ГТ-Р е bulletproof :smoke:
до 100 бил бърз, после ставал бавен ... "добре", баце :bowdown:
Този автомобил е извън закона, бе! Няма Вайпери, Корвети, Ауди Р8 и прочее...
Мнение от acho.rs » 20 Окт 2010, 17:04
З 06 си го бие магистрално и то доволно . Вайпъра още повече . На писта стоков ЗР1 пак дава по-добро време а на ускорение го размазва . Никой не казва , че е бавна кола , но чак пък най-бързата и без аналог , не е .
Регистриран на: 5.01.2006
Мнение от meha » 20 Окт 2010, 17:04
vicho написа:Този автомобил е извън закона, бе! Няма Вайпери, Корвети, Ауди Р8 и прочее...
така е...на черното не може да кажем бяло :yes: :yes: :yes:
Нисана си е Нисан :bowdown:
Потребители разглеждащи този форум: alx, Bing [Bot]
